I cant seem to get these out to replace them. Any tricks? I tried pulling. And then tried a screw driver to pry. And broke the ears off as u can see.
Ill give that a shot. Can i lube it with anything?I had luck cutting up the grommet in an attempt to loosen the elbow. I took it apart in little pieces. It didn't take much and the elbow was loose enough to remove. I had planned on replacing the grommet anyways so it wasn't a big deal.
Thats an idea too.I wonder if you could warm up (soften up) the grommet with a heat gun, or hair dryer?
Ill try that too.Maybe just leave the elbow in the grommet and pull them out together and then get the elbow out once it’s off the engine
You shouldn't need to. If your grommets are like mine they'll break pretty easily. They're pretty thick so getting them out of there frees up a lotta space quickly.Ill give that a shot. Can i lube it with anything?
Ya. Thats my concern. My valve cover is on.You shouldn't need to. If your grommets are like mine they'll break pretty easily. They're pretty thick so getting them out of there frees up a lotta space quickly.
Disclaimer: My valve cover was on my work bench at the time so there wasn't a risk of dropping grommet pieces into my cylinder head.
I have both new elbows and grommets. But it feels like a bit of dirt between the elbow and grommet. So the elbow isnt easily sliding out. Also probably cause the plastic and rubber are so old and stiff.Replace the grommet and the valve. They’re usually brittle. Destroy, make sure to not get any pieces down in there. Easy
What a mess. I don’t remember any grit in mine. I think I used a flathead screwdriver and some finagling, twisting the valve, and worked it out. Hopefully you can massage the “old and stiff” and make it young and pliable. The heat gun was an idea, but not sure it isn’t used to that kind of heat in the engine bay. Worth a shot. Wear gloves!I have both new elbows and grommets. But it feels like a bit of dirt between the elbow and grommet. So the elbow isnt easily sliding out. Also probably cause the plastic and rubber are so old and stiff.
Thats my new tagline. "To old and stiff."
Mr Dale makes it look easy!
Did that & it worked greatMaybe just leave the elbow in the grommet and pull them out together and then get the elbow out once it’s off the engine
