im installing a MML and I can't get the through bolts loosened, any tips on how to get those bolts out, btw I have a 1999 so the AC compressor is in a different spot so no worries for that
Use a jack to support the engine NOT BY PUTTING IT ON THE OIL PAN but by lifting from the bellhousing of the transmission. Use an adjustable wrench on one end and a large ratcheting wrench or preferably a breaker bar to loosen the bolts. If you have access to an air or battery powered impact just use that.
