managed to get mine out unscathed with a little bit of a fight and some patience + time.. they were concerning though, definitely didnt want to just come out in one go.
I soaked for 2 days with kroil prior to touching them. slightly loosened like maybe a 1/8th of a turn, sprayed penetrating oil on it again and tightened it back in place, loosened a little more, sprayed, tightened, etc etc. dont try it all in one go. give the bolt a little time to work itself clear, loosen lube tighten loosen lube tighten. should work itself out if you take your time.
cleaned my bolts and threads, smothered the bolts in antisieze and set them back in place. ill probably go stainless in the future if they snap.
