97 TJ starts but then dies
Just empty every pocket
N.Texas
Ok I know this has been around but I have tested and replaced just about everything new pcm, crank sensor, cam sensor, cap,rotor, plugs and wires, checked fuel press and finally ck injectors and after starting the injectors quit firing. Thinking I got a bad pcm
If you don't have an OBD2 reader you can cycle the key from off to pre-start 3 times (off click click, off click click, off click click) without andtrying to start it. My 97 will show codes in the odometer to what could be wrong.
See if it will remain running when you hold the gas pedal down just a little. If it will, your IAC (idle air control) is dirty and just needs cleaning which is easy. If it is, there's an easy way to clean it.
Reactions: D M
Have you checked the battery and or alternator? When my alternator crapped out on me my jeep wouldnt stay running
I am pretty sure the same thing happens when I accidentally grab my spare door key that doesn’t have a transponder.
No codes
No security key
3-5 seconds and it stalls the noid test shows injectors stop firing
You stated fuel pressure was checked, what pressures were you seeing.
40 key on 49 run
Yes bat is holding 13 v
Reactions: D M
We just purchased a new computer and had a program to our Vin number and our jeep is doing the same thing gauges work. It starts up runs for about 30 seconds then dies out no matter if we give it gas or not. Did you ever favorite your out what was wrong with yours?
Reactions: Wranglerfix
@Wranglerfix may be of some help here. Sounds like a potential SKIM issue.
@cmcredeur The skim function is activated on the ecm. We can disable that for you if you would like to send it in.
  • USA Proud
Reactions: hear
