Dyl Member Joined Feb 19, 2021 Messages 66 Location Zamunda Aug 22, 2021 #1 It seems to go inside cabin as in first pic and connects to a box or something (2nd pic). What is it.
deadbeat son TJ Addict Joined Dec 28, 2020 Messages 1,113 Location Denver, CO Aug 22, 2021 #2 Vacuum line. The "box" is a reservoir, and it goes into the cabin to control your blend door, which is what adjusts airflow according to the settings of your climate controls. Reactions: Chris
OP Dyl Member Joined Feb 19, 2021 Messages 66 Location Zamunda Aug 22, 2021 #3 I see, thanks for the information. So what does the reservoir contain? Also what's blend door
JKP TJ Addict Joined Aug 20, 2020 Messages 1,573 Location Warner Robins GA Aug 22, 2021 #4 Vacuum reservoir. The blend door blends hot and cold air as you adjust temp control. Reactions: Chris and Dyl
V Vinman TJ Enthusiast Joined Sep 20, 2018 Messages 992 Location Calgary, Alberta Aug 22, 2021 #5 Dyl said: So what does the reservoir contain? Click to expand... The reservoir contains absolutely nothing. Reactions: Dyl
FarFire70 TJ Addict Lifetime Supporting Member Joined Oct 7, 2020 Messages 1,005 Location USA - NE Aug 22, 2021 #6 I recently removed the fenders and pulled out the same box. I figured it was vac related, good to understand which vac system it assist.
Chris Administrator Staff Member Ride of the Month Winner Joined Sep 28, 2015 Messages 71,102 Location Gillette, WY Aug 22, 2021 #7 Vinman said: The reservoir contains absolutely nothing. Click to expand... Actually, it’s a little known secret that this reservoir contains the blinker fluid. Reactions: Plumber1, Vinman and FarFire70
V Vinman TJ Enthusiast Joined Sep 20, 2018 Messages 992 Location Calgary, Alberta Aug 22, 2021 #8 Chris said: Actually, it’s a little known secret that this reservoir contains the blinker fluid. Click to expand... *used* to contain… Reactions: Chris
