2000 TJ, after it was left with the top down in the rain, the low beams will not turn off. This was in June, the interior has dried out, but still the same. I replaced the headlight switch with a new one from the parts store, no change. Only the low beams stay on, I can turn on/off the parking lights and high beams.
When I unplug the headlight switch, the lights go out.
Unplugged, key off, from this images pins 3, 4, 6, and 8 are all hot.
With the switch plugged backed in, lights in the off position, also pin 2 is now hot.
Here's my question, did I get a bad switch (does the same thing as the original), not likely. Or, are one of the pins that are constantly getting power, not supposed to be, and it's back feeding the low beams.
