Set up: 04 TJ with 2” lift from PO. 33” General All Terrain tires
Issue: I have been working on swapping/fixing pretty much everything related to suspension and steering since purchased. i am still fighting the slightest bit of vibrations in the steering wheel (and cab at high speeds). At pretty much any speed. Take it up to 65-70 and you feel like you’re riding a rocket, almost rattle your teeth vibrations, but not a lot of steering wheel play or anything like that. Just loud and vibe. If you let off the gas, vibrations are reduced by 75-80%. Any thoughts? Maybe motor mounts? I included a pic of what I would consider the worse of the two.
Also: I am pretty sure when I got the tires mounted they did a crapy job balancing them. Going to take them to get rebalanced today.
Any additional thoughts?
Thanks!
Thanks!
