Drooping driver fender
Jack_Stefan
Los Angeles
The car had a minor head on collision from the previous owner but everything about the frame is straight. Except the driver side fender droops just slightly.
was wondering if there’s a way to fix this? My future plan is to repaint the whole Jeep in the same color. So I’d like to address specific body panels before painting.
Or should I just ignore it and buy a new fender when I decide to repaint?
Check out the photo. Ty guys.
I'm no auto body specialist but with good pair of gloves you could probably pull that back up. I'd probably remove the flare if I really wanted to be careful. The fenders are pretty weak sheet.
I'd probably get a floor jack, remove the wheel, get a 4x4 with a 2x4 on top, T shape , then raise the jack in an attempt to bend it back.
Thats the tip- basically make a porta-power - just distribute the load at the fender or you will create a new issue there.
That one is just tweaked- go easy.
Check the inner fender brace to see if it's bent. There is a brace panel a few inches behind the front turn signal, if it's bent it'll pull the fender down in a droop like that. Might be something as simple as straightening it back.
I used a floor jack and 2x4’s once. It was only ok. I would replace it before painting.
I’ll check this out in the morning!
