I just ordered a DirtWorx rear bumper, which comes in bare steel. I had planned to just use Rustoeleum Enamal paint. The shortcoming with that is drys from the top down. This makes a film. If you wait too long and spray your next coat over this film, the solvent in that coat will disrupt the film, it'll wrinkle up, and you have to start over. I hear this can even happen if you do a touchup months later.
This can be solved with lacquer paint. They tend to dry from the bottom up, because the evaporating lacquer keeps the upper layers hydrated until completely dry. Touchup and additional coats can be done at any time (well...as long as it's dry enough where your additional coat won't cause a run). I'm just not sure it'll be durable enough though.
Epoxy can be a bit more expensive ($20 for primer + $20 for top coat) but would be the most durable option. However, these are 2-part systems. Once you push the button on the bottom of the can, a reaction starts and you have a limited amount of time to use it. That might make it difficult to paint all sides of the bumper. Also, unless the can is held vertical, I hear it tends to sputter. There is, however, Rustoeleum applicance epoxy. I think I could use it over regular primer (not sure) and it's fairly cheap. It's some kind of one-step epoxy so probably won't be as strong, but touch-ups would be possible and I'm sure it'd be stronger than spray paint...probably splits the difference between paint and powdercoat
So...do any of you experienced painters out there know anything about the pros and cons here? I have a Jeep trip next weekend so don't have time to get it powdercoated, plus that's kind of expensive anyway.
