Will this shifter handle work?
Rickwhoo
Moscow PA USA
I want to replace my shift handle with something different. Has anyone found one? I want something like this... Not sure if this one would work.
Reactions: LakeBeard
I wouldn't mind a different T-handle on my shifter but I wouldn't want another that had the button on top like some of my cars had years ago.
How about doing away with the button altogether? My TJ is manual, but I never grokked the button thing - my old MBZ doesn't have one.
I installed a similar one a few years ago with the button on the top, I just recently reinstalled the factory handle as I found that the factory handle was just more comfortable and natural to use, the only benefit I found with the other one was that my knee did not hit it quite as much. Just my thoughts and opinion, hope it helps.
X2, that's why automotive factories stopped making automatic shifters with a button on top as my dad's '62 Oldsmobile Starfire came with.
I even made sure to use a T-handle on the B&M shifter I installed onto my previous TJ.
I want this setup on my 42RLE 😍
Surprisingly no you don't. Its shifting qualities absolutely SUCKED, it's next to unusable with a 32RH or 42RLE. The reason being is the B&M shifter exits its shifter cable toward the rear and it has to make a huge and long (!) front to rear loop back to to the 42RLE. The OE shifter exits to the front where it makes a short u-turn back to the transmission.
I could barely get mine to shift gears, it worked but I regretted converting to it. It sure looked cool though.
Damn, that’s a crying shame because I love the way that setup looks. What a bummer!
Reactions: Jerry Bransford
Jerry, no offence but every B&M auto shifter I ever owned was horrible.
Don't they work ok for GM/Ford transmissions where the shifter cable attaches at the rear of the transmission, rear to front?
I've had them in a few muscle cars and one of my race cars. I would never buy another one.
The one you want is a Winters Performance/Art Carr shifter like this one. It's a great shifter.
The Winters is absolutely the best, that's what I'd go for if I was to do it for my present TJ.
Reactions: williambmac
