I’m still debating the Atlas vs Rubicon 241 conversion from my 231 and looking for some input.
I have a 2001 with the 4.0 and the 32RH running the UCF ultra high clearance skid. I’m curious if anyone has swapped the Rubicon 241 into a rig with this configuration. More curious of clearance to the skid as the 241 is larger. I have a 1.25 BL and it looks like I should have clearance above.
That all said I am also running the 231 cable shifter so I’m curious if that will convert to the 241. The other write ups dial in the electrical for the most part but I’m slightly confused on the speedo. The 231 is gear driven and the 241 is electronic. So all one needs to do is adapt the current gear driven wiring to the electronic via a plug/wire pin change? Lastly, does one need to swap the SYE from thr 231 to the 241 or is the 241 already SYE from the factory?
Any support is appreciated!
