Eddie Greenlee TJ Addict Supporting Member Joined Mar 5, 2016 Messages 2,613 Location Mississippi Dec 31, 2020 #1 What is this and why would it be ticking fairly loud !!
mrblaine Crew Member Supporting Member Joined Nov 20, 2015 Messages 29,061 Location Quail Valley, CA Dec 31, 2020 #2 Eddie Greenlee said: What is this and why would it be ticking fairly loud !! View attachment 214706 Click to expand... Solenoid Purge Valve and that generally means it is dead and needs replacement. Reactions: Eddie Greenlee and CharlesHS
Zorba "The Veiled Male" Supporting Member Joined Apr 2, 2020 Messages 14,332 Location Merritt Island, Fl Dec 31, 2020 #3 RUN! Reactions: Blondie70, MikeE024, Jerry Bransford and 3 others
OP Eddie Greenlee TJ Addict Supporting Member Joined Mar 5, 2016 Messages 2,613 Location Mississippi Jan 1, 2021 #4 mrblaine said: Solenoid Purge Valve and that generally means it is dead and needs replacement. Click to expand... Hey mrblaine what do you make of this rattle / knocking sound? It’s up front under the hood but sounds low. I can’t tell if something is loose or wrong in the bell housing. Attachments IMG_2780.MOV 31.2 MB
JMT Just another auto... Supporting Member Ride of the Month Winner Joined Feb 27, 2017 Messages 22,633 Location 🌎 Oct 30, 2021 #5 Resurrecting this thread because I found this was my problem. Solenoid purge valve needs replacement. Do I need the Mopar part or not?
J JeepJeep1 New Member Joined Nov 1, 2022 Messages 3 Location Hawaii Nov 12, 2022 #6 JMT said: Resurrecting this thread because I found this was my problem. Solenoid purge valve needs replacement. Do I need the Mopar part or not? Click to expand... Having the same issue. I am wondering did you end up going with the Mopar part or ?
OP Eddie Greenlee TJ Addict Supporting Member Joined Mar 5, 2016 Messages 2,613 Location Mississippi Nov 15, 2022 #7 Actually I never replaced it. It stopped ticking so I left it alone. Reactions: Blondie70 and Wildman
