Ok I run 30psi but my rear look flatter than my fronts, regardless the psi I choose do you guys run even psi rear and front or do you run higher in the rear?
My springs are balanced quite well so empty tub a full gas tank flattens my rears but my fronts stay the same spring height stays the same regardless.
Cheers
Cheers
