FYI, any conventional oil is fine. You can even change or combine. It really does not affect things one bit. Just run the right weight. Synthetic only helps if you live in a very cold environment.Topped off the power steering fluid, greased up the steering linkage, and checked the other fluids. I have no idea what engine oil the dealership put in but after 3000 miles it still looks clean. Maybe I should ask them when I bring it in for maintenance.
Also dumped a can of Seafoam in the tank to see if that will help start it better. If not then seriously thinking it's a fuel filter issue.
