Not even a whole week after replacing the water pump, the radiator ruptured. I JB welded the crack as a temp fix while I wait for the new radiator to be delivered. Today I drained the old radiator to remove it so that I'd have a head start when the new one comes in, and what came out has me pretty concerned.
This isn't coolant. After I patched the radiator, I filled it with Thermocure rust flush and distilled water. It's very cloudy though. I also noticed some thick white substance deposited in the radiator hoses. December 24, I had accelerated really hard and heard a LOUD pop, had a coolant leak from the water pump, then parked it for a couple weeks until I replaced it. Then when I replaced the water pump, it wouldn't start back up until a week ago. When it did start, it idled roughly and threw a LOT of white vapor out the exhaust, but after a few minutes it ran fine. I also checked the oil level today and it is super high and I did not get consistent readings.
So on a scale of 1 to "grab some frosted flakes to go with that milk", how concerned should I be that the head gasket is blown? That is the conclusion I'm coming to.
Continuing from this thread: https://wranglertjforum.com/threads/need-help-diagnosing-no-start.58786/
