Sending all the nudes you've collected over to Andy?I guess I know what I’m doing tonight.
Why would you want to make it harder on yourselfPost count has nothing to do with posting photos. That’s a user error. Maybe I need to do a YouTube tutorial on how to post photos. I should do that, I just avoided it since it’s ridiculously simple as it is.
Fixed itPost count has nothing to do with posting photos. That’s a user error. Maybe I need to do a YouTube tutorial on how to post photos. I should do that, I just avoided it since I really do want nudes sent to me.
those pucks between the frame and the skidplate are called a transfer case drop.
Can't you just winch it up?I have a rear sag...I'm in the process of installing 4 H&R coil springs which should lift me 1-1.5" and Bilstein 5100's all around. On the front there is a 3" "budget boost'" and 2 different coil springs in the rear, once everything is installed, I'll go from there. Today I did install MOOG sway bar links and sway bar bushings.
You do have a drop on the t-case skid which is why your linkage was fuckered.
If they’re from good looking women, sure!Fixed it
Yep. I did that 4 times. Waiting for them to load. 100%. All 5 photos. Then I hit post. My text shows but not photos after hitting postInsert image is not the way to go about posting a photo properly. Do you want to use the attach files button right next to the post reply button.
He's from Bama he won't mind!!!!!If they’re from good looking women, sure!
It’s nothing but Thunderheads dick pics. I hope Andy is okay with that.
Beauty is in the eye of the beholder or put another way, for every seat there is an ass.If they’re from good looking women, sure!
He said he was. He was trying to hold back his enthusiasm unsuccessfully.It’s nothing but Thunderheads dick pics. I hope Andy is okay with that.
If there's no lift on the Jeep why would they drop the TC? Apparently the coils are longer in the front than stock. Did they have to do a drop for that?You do have a drop on the t-case skid which is why your linkage was fuckered.
Thanksyes, attach files, they upload, you then select insert and have the option of fullsize or thumbnail. View attachment 317337
look, even stock the coils on the back are shorter than the front. they dont look like stock coils. it is probably lifted the same amount front and rear. your just getting wrapped around the axle about the springs being different lengths.If there's no lift on the Jeep why would they drop the TC? Apparently the coils are longer in the front than stock. Did they have to do a drop for that?
I'm sure ur right. My confusion I guess was that the back springs measure the same as factory coils. 8" .It looks like it has a small lift 2.5 probably, hence the small Tcase drop. you need to read up on how to measure for proper shock lengths and bump stops. surely someone around here has a thread on that in the sticky section.
