Why would some one put a bigger coil spring in the front?
Post count has nothing to do with posting photos. That’s a user error. Maybe I need to do a YouTube tutorial on how to post photos. I should do that, I just avoided it since it’s ridiculously simple as it is.
Why would you want to make it harder on yourself :ROFLMAO: 🤫
I have a rear sag...I'm in the process of installing 4 H&R coil springs which should lift me 1-1.5" and Bilstein 5100's all around. On the front there is a 3" "budget boost'" and 2 different coil springs in the rear, once everything is installed, I'll go from there. Today I did install MOOG sway bar links and sway bar bushings.
Can't you just winch it up?
Insert image is not the way to go about posting a photo properly. Do you want to use the attach files button right next to the post reply button.
Yep. I did that 4 times. Waiting for them to load. 100%. All 5 photos. Then I hit post. My text shows but not photos after hitting post
yes, attach files, they upload, you then select insert and have the option of fullsize or thumbnail. download.webp
You do have a drop on the t-case skid which is why your linkage was fuckered.
If there's no lift on the Jeep why would they drop the TC? Apparently the coils are longer in the front than stock. Did they have to do a drop for that?
look, even stock the coils on the back are shorter than the front. they dont look like stock coils. it is probably lifted the same amount front and rear. your just getting wrapped around the axle about the springs being different lengths.
Go jack up the back end by the bumper and have a big girl sit on the front bumper until the springs are the same length and then let us know if it is gonna ride even.
It looks like it has a small lift 2.5 probably, hence the small Tcase drop. you need to read up on how to measure for proper shock lengths and bump stops. surely someone around here has a thread on that in the sticky section.
I'm sure ur right. My confusion I guess was that the back springs measure the same as factory coils. 8" .
And the front were 2" longer than stock. But I definitely don't know about measuring shock lengths and bumper stops. Thanks for helping me!
