No PCM communication on 4.0
oogah
Kansas
so long story short, went to replace throttle cable then went to start and test out, didn't realize cable was too short and started it up with intake slightly open heard a loud click/clank, got cam/crank sensors not synched, pulled opda and replaced just to be sure, did tdc and all, now got a crank-no start and no communication to any code readers, any help is appreciated
Reactions: Wranglerfix
@oogah If the cam/crank are out of sync with OPDA it can cause a no start issue. You can also experience a rev limiter if they are out of sync. I am glad you found the issue! If you ever have any PCM issues I know a guy!!
@AndyG Thanks for the tag. Cookie and I spent the blustery weekend feeding our turtles and fish. Cookie is mesmerized by the turtles!
