T
Tdub
Guest
2000 Sahara currently have 32s and it looks like 33s would fit easily. Wanted to get confirmation before I pulled the trigger
Welcome to the forum!2000 Sahara currently have 32s and it looks like 33s would fit easily. Wanted to get confirmation before I pulled the trigger
33s on 2” of lift will “fit” but don’t perform well by really any circumstance and there’s a lot of other things to consider and upgrade when you move to 33s. I ran 33s on 3” of lift had to limit my uptravel to keep the tires out of the fenders.
Without know how your Jeep is built at all I’m gonna say don’t do it unless you’re willing to make other changes as well or are willing to have a vehicle that merely “looks nice” but that’s about it.
Sure,add at least 1" bodylift and probably change your bumpstops and you're good
Okay this helps. Thank you
I was being sarcastic. Gearing,steering and other things are an issue too
Appreciate your honesty this time but why be a dick the first? I’m just trying to learn and I’m sure you were once too
Asking a TJ forum for advice is research troll. You’ve a member for two years so prob go back to the basement
You just got good advise,get to it
Why are you still here tinyd? Your excused
