Sounds like I could use a new sub too.
Well, thats suboptimal..
You guys and your puns.
If you're sticking with the factory amp and sub enclosure, this cheap Goldwood is all you need.
Swapped the hard top for the soft top after today hit 75 in the NE. Not quite ready for half door weather yet though.
liking the front bumper
Was this a snowier than normal year for you, Mac?
Yup...but I've been saying that pretty much every year for a while now.
Not arguing about wheeling in 3' of snow 20 minutes from home and no snow at home.
I drive for a living and drove my Jeep for 6 hours in 3' of snow, stop and go. Not fun after the first hour. No backup either.
He's dragging his feet on cleaning the oil pan mating surfaces
I don't blame him. Cleaning those can be difficult, but it can also be easy. If you have access to an electric or air die grinder, get some of these - it'll change your boy's attitude:
https://www.amazon.com/dp/B002P55TX6/?tag=wranglerorg-20
You'll also need a mount:
https://www.amazon.com/dp/B000FW4LC6/?tag=wranglerorg-20
Although knock-offs are prevalent, I stick to the genuine 3M versions, so I can't speak to the quality of anything but 3M stuff. Whenever you use them, mind the dust - it's very abrasive (those plastic bristles have abrasive impregnated into them), and you don't want it inside your engine. Also, they come in three grits: coarsest is green, mid is yellow, and finest is white. The green works fine on steel and cast iron, but if you use it on aluminum, be very careful, as it will remove aluminum if you're not paying attention. For aluminum the white version is much more forgiving, but still possible to damage the gasket surface if you're ham-fisted about it.
You can literally get the pan's gasket surface shiny-clean in under five minutes with those Roloc Bristle Discs!
Are you following designs from somewhere or is that something you designed yourself? Because that is actually what I've been trying to figure out how to do.View attachment 413676
Working on the drawer kitchen setup
I designed it myself
