Lift reduction (2 inch down to 1 inch)
so, I'm trying to understand the logic of how Quadratec and/or OME is listing things. See the images attached. For front, they say heavy load is 1.5", and for rear they say heavy load is 2".
Does that mean that they are retaining the rake by having the front 5." lower in front?
What are the part numbers?
I have 933x and had 942x ome springs in my tj.
I have a 6cyl and a winch. 933x gave 2" lift in front. Rear i have a lot of steel armor and got an inch of lift from 942x.
Is your jeep 4 or 6 cyl? Winch? Hardtop? These things make a big difference in actual lift height.
Reactions: imactj2004
6 cyl, hard top (plus some added second skin sound proofing which is prob another 25 lbs total weight), and a winch.
Part no’s are different depending on if its OME vs ARB OME.
I spoke with someone at Extreme Terrain who recommended “medium”…but the problem is that I cant seem to find OME or ARB OME that are 2” medium. Only “light”.
