I just got a 99 wrangler all stock except it's sitting on 31s with 15x8 rims, so the wheels stick out from the flares a bit. Since they stick out it wasn't until some time later i noticed the front axle is offset to the driver's side by maybe an inch. I noticed the lower control arm mount on the passenger side was bent and long story short had a shop swap in another front axle with a straight mount. It's still offset, and even before the axle swap I noticed even the rear axle is offset to the driver side by a little less than an inch.
Coincidentally, the day before i brought it to the shop I saw another stock height TJ with bigger than stock tires like man, and he had the exact same offset. we were driving so I couldn't get under it to inspect the setup, but being behind i could see they were biased towards the driver side. Is this a normal thing that i've never noticed on TJs before? I had a YJ in a previous life.
I have searched a bit but all the threads I found were concerning lift kits, which I don't have. At least I don't think it does.
Looking at the new axle, the spring on the passenger side is a little further from the wheel joint and the suspension in the front does feel slightly softer, so at least the new axle wasn't a total waste. I'm not terribly familiar with suspension parts and what they really do so I'm not sure where to start. The guy at shop has had plenty of jeeps and didn't seem too concerned about the offset so much as he was about the bent control arm mount, but maybe he doesn't wanna deal with, it who knows lol. any help is appreciated! The shadows make it a little hard to tell in the images on the rear, but the front is pretty obvious.
