Jimy
The axles shouldn't be offset. That said, factory fresh vehicles had a lot more variability to them than you'd expect. In regards to lifted Jeeps, any ride height change from stock will also affect the centering of the axles. You have a track bar (or called a panhard bar in a lot of other automotive circles) that runs left/right and connects the axle to the frame. This controls the side to side movement of the axle in relation to the chassis. Because it runs from the axle to the frame, when you raise or lower the vehicle it travels in an arc and results in an offset. This can be fixed with an adjustable track bar. You would install the track bar then adjust the length to get the axle back under the center of the Jeep at ride height.
What's odd in your situation is that you're saying both axles are offset in the same direction. The front and rear track bars mount in the opposite direction of each other, so when a height change offsets them, they offset in opposite directions.
My question would be what caused the bent control arm mount? If there was damage to the mount there could possibly be other bent items like the track bar mount at the frame, the track bar, or even the frame itself. Maybe some pictures of the various connections could be helpful, or even a trip to an alignment rack to see if something's out of square.
@bluescapegoat, thanks for the explanation, I had the similar situation here, I have 2005 TJ with 2 inches lift sitting on 33 inch tires, and as I can see the right wheel is sitting like 1 inch more out than the left wheel, so this is normal because of the track bar logic. but front wheels seem symmetrical, is this normal? only non symmetry on back wheels after lift? greets from Germany
