Out with the old springs, in with the new…..3” in front 2” in back. Measured for shocks and now I gotta do it all over again. NOT looking forward to that! I also cleaned the dried up mud/ sand out of the jounce stop tubes(?)
Core sample from the passenger side
Used a piece of split flex conduit and some weather stripping to adapt the vacuum cleaner wand. (Don’t tell wifey!😂)
Bad angle but she looks good in her high heals
I like the steel wheels!
I made a 'harness' for my three new OEM-style panel switches. They'll share a common ground on a bolt behind the stereo, and a common power source with a connector at the firewall. They're doing in separate directions or else I'd put them in some wire loom.
Connector is there so that I can tap into that 12V supply with a splitter if needed for any other future (low-amp) accessories inside the tub. Of course each white wire will be run to the relays in the engine bay.
