Unknown bracket above tail light
Redfishbc
Prospect KY
Hey, just picked up a 2004 Rubicon. Can anyone tell me what the two brackets above the tail lights are for? These brackets have a large bolt mounting to the body. Googled it every way possible and found nothing.
It is an antenna mount. Maybe they had two because one was for a HAM radio and the other for a CB. Or maybe they used one for a Flag and the other for a CB. They are definitely antenna mounts. You should be able to remove the tail lights and take them off if you don't want them.
Reactions: inkedrose and AndyG
I googled antenna mounts. They are similar but the brackets I have are not flat on top. It’s round like a door hinge. Maybe it’s an antenna mount, but then why two of them. So strange.
Do you have any better pictures?
Ok, thanks for the help on this. Guess I need need to start researching CB radios now.
Yeah... Those have to be some sort of mount/bracket for a roof rack or other accessory. Definitely not like any antenna mount I've ever seen.
Reactions: Zorba
They look like the mounts for an exo- style “roof” rack… @AndyG ?
Antenna mounts, I have one on the left rear of my LJR-
Remove them if you don’t need them- they will start rust between them and the body.
"That's no moon..." - it isn't an antenna mount either. Since I don't know anything about a possible roof rack, I won't jump on that bandwagon, but it sounds likely to me.
