Hi TJ Forum,
Couple of questions as I am planning out some upgrades to my 04 Rubicon. My ultimate goal is fit 35s under her. I am contemplating two paths, 1)high line fenders, 2)body lift. Jeep already has an unknown lift of some brand and height.
- Is there a way to determine how much lift is on the jeep from the existing springs? I know it is lift but not by how much. Currently run 33s (measured 31) without rubbing on stock fenders.
- I am hoping/guessing I have 2.5-3" of lift thus to get 35s I understand a body lift is the easiest path forward.
- If I do the body lift, I understand a motor mount lift is not necessary so long as I move the fan shroud and make new holes ~1" above the existing ones?
- If I do the body lift, are the drive shafts still long enough? I am less concerned about the front but I am not sure about the rear or if I would need to order a new one.
