2005 TJ, 4.0
I replaced the starter. Had the battery tested. Good. Cleaned the grounds. Ran a direct negative cable to the block. Ran a direct positive cable to the starter. Put on brass post connectors. Starts sometimes. Single click other times. Out of ideas.
