That chunk of metal must’ve been pretty heavy to warrant a rolled up sleeve and bicep flex like this…
Heck, even I can figure out why you did that!Ryan, Ben and Mike - who watched me weld Ben's lower rear shock mount back together - know exactly why I did this...
Heck, even I can figure out why you did that!![]()
I felt pretty bad for him watching blood run down his face.
But not quite bad enough to take on the job yourself?![]()
I've had this thing for many years, and it originally had something like that pad on there - but it had long since fallen off and been discarded. I've never thought much about it until I was rolling around under Ben's jeep, smashed the mask into his rear axle, and sliced my nose open. Ultimately, I figured out that the cut was caused by those sharp rivets.
I did not realize it happened until I stood up and took off the mask.
Ben said, "Jeff, you are bleeding pretty badly, are you OK?"
Mike said, "I'll get my first aid kit and help you stop the bleeding." (Mike has some experience there).
Ryan said, "Get the &(*#^ back under there and finish that weld!"
This is the most important mod I've done since getting home. Ryan, Ben and Mike - who watched me weld Ben's lower rear shock mount back together - know exactly why I did this...
What did you use to attach it?
I'll need to look at the one I purchased and see if it needs your padding too.
The padding on mine needs to be replaced too
Your collective noses will thank you.
Will it still fit with a clear lens?
