That welder must have gotten his GED (good enough degree)Yep, you can still see the edge of the original plate. absolutely no penetration. I'd bet the other piece has no weld metal left on it.
That weld was wrong before an arc was even struck. That's a high stress joint so I would have beveled that edge to get complete joint penetration. Also could have welded both sides but I don't know the whole geometry of the joint. As for the other weld it was probably solid, but there was so much dynamic force when the weld popped it mangled everything. That existing bend line was probably on both sides so when it folded over that initiated the crack & the stress followed my red line until it hit the toe of the other weld (stress riser) causing the second crack. Also I see another crack by your hand, was that area bent by the manufacturer?
