The real test is a twitchy little trailer that you can barely see. Have you backed it up with one of those yet?
I'll tell you what, I'm pretty good with a big trailer. I've been towing good sized stuff for well over 40 years. When I got this thing, I never thought I would use the backup assist, but I set it up one day just for kicks (it takes a bit of configuration). It works crazy well. Especially on long straight reverse runs. I'm almost embarrassed to say I'd use the thing occasionally.
Big trailers are easy! Its the short, narrow ones that will challenge you. I used to have a 4x8 utility trailer with about a 4' tongue. Before B/U cameras, you'd have to drop the tailgate to even see the damn thing, and if you moved the steering wheel more than a few degrees either direction, you better be prepared to stop. It would cross up right quick!
