just mount one of these on the front of your Jeep !
You talking about the one in front or one of the three behind it?
Small
Update
If i am at idle and temperature rises to 225 and i turn off the AC the temp starts to decrease to 213-214
Nothing meaningful there, but that does reinforce my thoughts that your fan clutch isn't strong enough to move the needed air.
That IS NORMAL. The AC will add extra heat to the system because of how AC systems are designed. The condenser is on the front of the radiator so that heat is passing through the radiator.Small
Update
Small
Update
This is normal,my system is all new and all mopar,on a hot day we have to turn the ac off if we get stuck in traffic,ect.now that I have the better tupy head ,I wonāt be so concerned about slight temperature swings as much.
