- Price
- $30-$60 + shipping
- Location
- Eastpointe, MI
I have a few different parts left over from some recent upgrades. Everything is in decent condition and works as it should. Both of the harnesses work well but not all factory plugs are intact. More info below.
OEM Tailgate Hinges w/hardware - $40 —- Painted tan by the previous owner. This was not a properly done paint job. Factory SILVERSTONE METALLIC CLEAR COAT is underneath. Includes original hardware. Some light surface rust on the back, easily cleaned. These work properly, I upgraded to the Moryde kit.
OEM Third Brake Light - $30 —- Should work fine, it was not installed when I bought the Jeep but the PO included it.
OEM Windshield Washer Reservoir, Single Pump - $30 —- This will be cleaned.
Tub Harness for Soft Top with Sound Bar - $60 —- The sound bar plug was replaced with a generic plug to use the dome light. I will include both sides of the plug.
HVAC/Dash Harness - $60 —- It appears to have the plug only for fog lights which I don't believe mine had from the factory. The portion for the fan speed is missing the plug but has spade connectors in it's place, this is how it was when I bought the Jeep and worked as it should. The plug for the cigarette lighter is also gone and was wired for an aftermarket USB charger. The factory speaker plugs are in tact but are also spliced off when someone tried to wire up tweeters. As long as I've owned it, they have not been connected.
HVAC and cigarette lighter connections.
Speaker Plug
Picture for reference on how it was plugged into the fan speed control
Speaker Plug
