Put led headlights in my 99 Jeep Wrangler.How do I hookup daytime running lights it has one red wire.Thanks
Otherwise, if you just want them as DRL's (not having to turn on your parking lights), just use a relay that is powered by an ignition "on" circuit. Fuse the wire, though.
On a standard automotive relay-
Pin 30- fused battery plus
Pin 85- trigger voltage (your ignition "on" source)
Pin 86- ground
Pin87- out to your halos, DRL's, etc.
If you're just running LED halos, I would think a 5 amp would be fine.
I just did mine a few weeks ago, I'll go out tomorrow and get pics. Mine come on when the key is on. I tapped in under the hood. There is one under there...You don't need to go into the cab.Put led headlights in my 99 Jeep Wrangler.How do I hookup daytime running lights it has one red wire.Thanks
I just installed LED headlights on my TJ and it has a DRL wire that I taped off since I don't care to use it for parking lights. Ever since I installed, my battery keeps going dead. Lights work fine and they we're plug and play with no wiring needed. How is this possible??!!
Mines a '98. This will be "on" when the key is on.Put led headlights in my 99 Jeep Wrangler.How do I hookup daytime running lights it has one red wire.Thanks
Do you use an inline fuse for the DRLs? Also is that just a regular spade terminal that’s fits tightly? Thanks
Were you able to determine which fuse slot you used that is controlled by the key?I just did mine a few weeks ago, I'll go out tomorrow and get pics. Mine come on when the key is on. I tapped in under the hood. There is one under there...You don't need to go into the cab.
This might be a dumb question, but you did exactly what I plan on doing. How did you determine which wire to tap into for the halo? I also have Amber turn signal halos that would work if I tap into that wire correctly.Fuse tap if you want them on all the time.
I don't care about that so I just tapped into the marker lights on either side. Have halos on with the running lights.
