They do block the wind from the rear somewhat. With the doors off, I'm not sure that will help all that much. I ran a windjammer on a couple of previous Wranglers, TJ & JK, but eventually they ended up in a box on the shelf for good. I didn't like how it limits your rear view. IMO only.Im just looking for it to cut down on the wind coming in at highway speeds.
You're welcome. I used to see a TJ that ran a bikini/windjammer/tonneau cover year-round, so someone likes what they do!
I've been running one of Bestop's wrap-around windjammers with my Trektop NX in "safari" mode since early April/late March. Run it top on, top off, window uppers on, just lower doors, and once so far with doors totally removed. I do have one of the sun shades/screens from Alien installed so have yet to run it truly topless.Are windjammers functional with the top back and doors off and with a safari top?
Yeah I have the same issue... I'll usually tighten up the straps as much as I can and then just put the seat back. Things seem to work themselves out especially when everything warms up in the sun.The problem I had with my Windjammer was if it was installed with its straps cinched enough to make it taut, it blocked my seat from being slid back far enough. At only 5-11 my seat doesn't need to be slid back all that far but it stopped the seat before reaching that point.
See: https://wranglertjforum.com/threads/windjammer-question.21413/Mr. Bills said:I used to run a full length safari top on my CJ-7 with half doors and a tonneau cover over the rear deck. I added upper soft doors and a Windjammer in bad weather. There was some rain intrusion around the upper doors but it was good enough for all but the heaviest downpours. I had no issues with interference between the Windjammer and the seat backs, even when the seats were adjusted all the way back and the seat backs touched the Windjammer.
