Finally upgraded my stereo today. I had no idea what I was missing.
Speakers, a sub and an amp are on the list.
Talk to @pcoplin at full stack motorsports about tuned shocks for the outboard. I'm gathering much of the same parts right now for my build.Well, this happened today.
Savvy Mid-Arm coming soon.
I still have to order a Belly up skid and a 1” MML and I will be out boarding the rear shocks too.
These parts will have to sit on the shelf until I can buy the rest. But this was a huge step.
Yes, that is a problem. Loosen the bolts at the manifold, push the exhaust up over the mount until the pipe going around the front of the oil pan is parallel to the ground or higher on the right side and tighten it back up.Front Frame brackets are in. I sure hope they are correct. I’d hate to try and cut these out.
On pic #2 you can see my exhaust is resting on the bracket. I’ve not seen anyone post about this before. Think it’s a problem? @mrblaineView attachment 170745
@mrblaine are you saying where the down pipe connects to the manifold? Just above the cats? Or where the manifold bolts to the engine block?
This would have been in the instructions. Look at the top of the cast part of the diff. There is usually a seam or part of the casting that needs to be knocked down with a flap wheel so the arcs in the ends of the truss fit closer to the axle tubes themselves. That gap should go away.Not many pics today but I’m VERY happy to say all the brackets are cut off! I’m so glad that’s done!
I still have some flap disk work to do but it won’t be bad.
