Don’t tempt me!But. If you want to dream heres the best option https://www.hardbody4x4.com/5330-tj-cj-hybrid-body.html
Welcome back to level ground. Nice to see you again.Don’t tempt me!
Sounds like it’s either vinyl or Maaco for me.
What are you trying to sayI get what you're trying to do. I just don't think its going to turn out like you invision.
Maaco will paint the jeep for around 1,300, ca price, and it would certainly be a better paint job then you'll get from an aerosol can. You'd just need to pull the raw parts you don't want painted.
If @Jerry Bransford can go through JV without messing up all his paint I'd bet you could do the same with a good choice of lines and a good spotter. Just make sure to let @starkey480 lead so you learn from his mistakes lol.
Also the jeeps hood is going to blind you of it's brushed aluminum.
too soon??What are you trying to say
It’s only a matter of time out here lol. Chris get some flak jacket armor and aluminum trail doors and then literally the only body color you have is the hood loltoo soon??
It’s good to be back!Welcome back to level ground. Nice to see you again.
I always wanted one of those things growing up, part of me still doesPlease no rattle can. It will look good with the aluminum and khaki. Unless this is the look your shooting for?
As someone who has spray painted an entire car over the course of a couple of weeks by removing every panel and diligently obeying the curing times between coats, it can turn out much better than a shitty maaco job. Spray paint by someone who knows what they're doing is far superior to someone who doesn't with an hvlp gun and cheap paint (which is likely what you'll get at maaco).
This entire car was done with rustoleum painters touch dark gloss grey. No clear coat because I've never had good luck with it out of a spray can. Just prepped religiously and painted with an eye for detail. Used the existing paint (white) as the "primer".
