This summer my 05 LJ has been overheating a little at long traffic lights with the A/C on. The needle moves from left of the 210 dot (between 2 & 1) to the right of dot (between 1 & 0). I ordered and installed a Hayden 2771 fan to replace the original one. It’s better, but still overheating after about 4 minutes of idling. The G05 HOAT orange coolant that I put in 2 years ago when I replaced the radiator still looks great. I drained the cooling system and added flush to the system. After running the engine, I drained and filled it with distilled water again. I then removed and installed a new 195 thermostat. I refilled the system with distilled water again to see how it did. I drove the jeep to Home Depot and let it idle at home and after 7 to 8 minutes the needle did move to the right of the dot for the 210. Temperature does return to the left of the dot (between the 2 & 1). Better, but still a little hotter after idling than it used to be. The water pump along with the upper & lower hoses was replaced 5 years ago. Do you all think this is acceptable? I will be draining the system of the distilled water and filling with (1) gallon of MOPAR coolant, (1) gallon of distilled water, and top it off with 50/50 MOPA coolant.
