My LS is done minus an issue I am having with my fuel setup. I am running an aftermarket LS aluminum intake along with the billet fuel rails. My issue is i can't keep the fuel from leaking around the injectors on the drivers side. I am not running a return as the 05's did not come factory this way. I believe I am building up to much pressure that the fuel is blowing past the injectors ORINGS. So, do i need to run a return or a corvette type regulator?
