05 TJ Blower Switch
tomtaylz
LJR Addict
San Francisco, CA, USA
So on my LJ the fan only works when it gets up to the third "fan" setting.
I believe it might be an issue with the blower fan switch? Did something change in regards to this for the 05/06, everything I'm seeing is 97-04. Is there a part number for it, do I need to buy the whole unit? Or is it another issue all together?
Reading about it should I replace the blower motor too which seems to be the root cause?
I read the blower motor when they go bad draw too much power which blows the resistor. Not sure if thats valid.
It would be a good preventive. I just did the resistor on mine when it acted up, but you know how these TJ's are.
Reactions: tomtaylz
