Agreed.
Plus, I've never heard of a TJ wheel sheering all 5 studs.
Must be plenty strong.
4.88 or 5.13 for the manual. 5.38 for the auto. Revolution Gear and Axle chromoly axles. 17" aftermarket beadlock wheels with the appropriate backspacing. 17" big brake kit from mrblaine at Black Magic Brakes.
NSG370/34"/4.56=2839rpm @ 75rpm...
Also, I have a 6 speed manual, so I'm hearing that 4:56 wont be low enough? I want to be able to hit highways speeds, 70-75 MPH at around 3100 RPM which is what I do now with 33's and 4:10 gears in 6th. Feel free to weigh in and thanks again!
NSG370/34"/4.88=3038rpm @ 75rpm
NSG370/34"/5.13=3194rpm @ 75rpm
NSG370/34"/5.38=3362rpm @ 75rpm
4.88 is the minimum for what you want. 5.13 would be fine. There is no reason the Jeep wouldn't easily make 75mph.
Revolution Gear and Axle, chromoly axles. I will go with a 17" wheel and the 17" BBK from Mr. Blaine. My current rims are 15X8 with a 3.75 backspacing and a -18 offset (in speaking with a wheel guy at a recent overland show who inspected my rims and told me this.... ) He suggested I go to a 17X8.5 wheel size when I move up to 35 inch tires but the backspacing and offset should remain the same... this sound right to you guys?
it's looking like at least 4:88s
