I have no idea how I would do that but thanks for the info.They should be compatible for install, but I’d check to make sure the older clockspring is compatible with the newer airbag.
I searched and found that the splines should be the same among the years (36 splines) but I can't find anything that says definitively that the newer airbag is compatible with the older clockspring.I have no idea how I would do that but thanks for the info.
Glad your dad let you driveI wrapped mine in paracord.
Edit - here’s a pic. I wasn’t sure how it was going to turn out, but I ended up liking it. I’m not a fan of steering wheel covers so I though I’d give it a shot.
Yeah, my dad's pretty cool. I just wish he'd shut up about this TJ! I get it, you installed control arms & welded your own Dana 35 JJ bracket. Good for you dad, but the family doesn't want to hear about how great it is every single night at the dinner table.Glad your dad let you drive
https://www.amazon.com/dp/B018FM4X2K/?tag=wranglerorg-20
I put one on the TJ and liked it so much, I ordered another for my GMC Sierra 2500.
A bit tedious stitching it on, but great quality.
Do you happen to remember what size you ordered?https://www.amazon.com/dp/B018FM4X2K/?tag=wranglerorg-20
When measuring, it was right on the border of M and M-. Initially ordered the M- wanting a snug fit and couldn't get the seams together near the spokes. Returned for an M, which worked out perfectly and is what you see in the TJ pic.Do you happen to remember what size you ordered?
Perfect...thank you!When measuring, it was right on the border of M and M-. Initially ordered the M- wanting a snug fit and couldn't get the seams together near the spokes. Returned for an M, which worked out perfectly and is what you see in the TJ pic.
Yeah Dad may never hush up about the jeep, but that young man will ALWAYS remember this time driving !, (behind the steering wheel masterfully para-corded by his brilliant dad ).Yeah, my dad's pretty cool. I just wish he'd shut up about this TJ! I get it, you installed control arms & welded your own Dana 35 JJ bracket. Good for you dad, but the family doesn't want to hear about how great it is every single night at the dinner table.
Did you add the new wrap directly on top or did you remove the old wrap?When measuring, it was right on the border of M and M-. Initially ordered the M- wanting a snug fit and couldn't get the seams together near the spokes. Returned for an M, which worked out perfectly and is what you see in the TJ pic.
Directly on top; just laid it over and stitched it up. If you go this route, you'll want to make sure you go back and tighten the stiches every 5 holes or so using a J hook or something similar that's small and can get under the stitches (I used a hole-punch). That ensures the seam stays nice and tight and keeps it neat.Did you add the new wrap directly on top or did you remove the old wrap?
Great..thanks. Amazon should be delivering mine today!Directly on top; just laid it over and stitched it up. If you go this route, you'll want to make sure you go back and tighten the stiches every 5 holes or so using a J hook or something similar that's small and can get under the stitches (I used a hole-punch). That ensures the seam stays nice and tight and keeps it neat.
Around the spokes, you only repeat the stitches on the front side and skip the same # of holes on the back. When you do this, it takes a little trial and error to see how many that should be. I found on both the Jeep and truck that I skipped less than I thought I would in order to keep it nice and tight. It's in the instructions and there are a few YouTube videos out there on how to do these. It's not hard, just tedious and takes a little trial and error until you get the hang of it to see how to keep it tight and neat.
Rats....I seem to have lost mine!A Corset hook works well for this.
