It seems the issue is either fuel or ignition related. After a fair amount of research, I feel like I have some things to check.
The plan is to listen for the whirring of the fuel pump after switching on the ignition.
Also, we hope to check for a worn wire behind the valve cover and confirm if the plugs have a spark.
We also have not ruled out the ECM.
A couple of questions:
- If there is a spark, is the ASD relay or the crankshaft position sensor more notorious for going bad?
- If the fuel pump is bad will fuel squirt out of the schrader valve (its a no start problem)? Looking for an easy buttton to narrow down if its the fuel pump
