I'm having no luck with these blinker/hazards. They do no work 95% of the time, if I mess with the wires enough I can get them to either stay on solid or flash a few times... then nothing. I have cleaned the relay contacts, replaced the relay with an EP-27 (which does nothing), temp replaced the ground to the relay, and ruled out the switch (which seems to work fine when they are working). I have an after marker alarm system installed "AutoMate AM5" which operates the flashers just fine every time I touch the jeep. THOUGHTS?
