chiineserocks New Member Joined Oct 19, 2022 Messages 22 Location Maryland Oct 19, 2022 #1 They are so dim. Even when it’s pitch black it’s just barely lit up. Is there a way to control this? Now that i’m thinking about it, the shifter is also dim too.
joelachr TJ Enthusiast Supporting Member Joined Dec 13, 2018 Messages 343 Location Michigan Oct 19, 2022 #2 If 2000 model year has the headlights on the left stalk, there’s a ring there that twists to adjust brightness.
OP chiineserocks New Member Joined Oct 19, 2022 Messages 22 Location Maryland Oct 19, 2022 #3 joelachr said: If 2000 model year has the headlights on the left stalk, there’s a ring there that twists to adjust brightness. Click to expand... My Jeep has the thingy that you pull toward you if that makes sense. Reactions: joelachr
Daryl 2004 Rubicon Supporting Member Joined Apr 29, 2018 Messages 3,065 Location 🌎 Oct 19, 2022 #4 chiineserocks said: My Jeep has the thingy that you pull toward you if that makes sense. Click to expand... Twist that to adjust the brightness. Reactions: joelachr and Jerry Bransford
Chris Administrator Staff Member Ride of the Month Winner Joined Sep 28, 2015 Messages 71,101 Location Gillette, WY Oct 19, 2022 #5 LEDs will increase the brightness by quite a bit. Reactions: joelachr
DaveC TJ Addict Supporting Member Joined Jan 3, 2019 Messages 1,788 Location Gilbert, Arizona Oct 19, 2022 #6 Cheap and easy; well worth the small amount of time and $. https://wranglertjforum.com/threads...ghts-of-your-jeep-wrangler-tj-with-leds.9149/ Reactions: Jeep 541X
