Help need to pass smog test is there an easy way to fix or “by pass”? I suspect the evap lines on top of fuel tank are broken and probably leaking can i just plug the line? Any help appreciated
No, you can't plug it. First guess is your gas cap. Then the purge valve, then the leak detection pump. If you see cracked or broken lines, they're easily enough replaced.
If in doubt, have it smoke tested.
a piece of advise, if you replace your purge valve I suggest replacing your evap cannister at the same time. many times the charcoal in the cannister will leak and clog up the purge valve. if you just replace the valve it will just clog up and ruin the new valve shortly....
