2001 Jeep Wrangler 4.0 having P0455 code issue
01saharatj
Help need to pass smog test is there an easy way to fix or “by pass”? I suspect the evap lines on top of fuel tank are broken and probably leaking can i just plug the line? Any help appreciated
a piece of advise, if you replace your purge valve I suggest replacing your evap cannister at the same time. many times the charcoal in the cannister will leak and clog up the purge valve. if you just replace the valve it will just clog up and ruin the new valve shortly....
Decided to fix the boots with fuel hose. Little overkill but won’t have to fix again.
