My backup lights no longer work.
Here is what I know...
-The bulbs are good.
-Fuse #7 behind the glove box is receiving power.
-The switch on the transmission has continuity when in reverse.
-Purple/white stripe feeding the switch has no power.
-Purple/black stripe to the backup lights has continuity when fed directly from the battery. Meaning that the backup lights are working, but are not receiving power before the transmission switch.
It seems like the problem is between the glove box fuse panel and the transmission switch. Where does this wire go so I can narrow down the break in continuity?
