Looking for any updated recommendations for 2004 Jeep Wrangler X steering gear box recommendations. I don't believe I can do the Durango change out on a 2004. Suggestions appreciated. Happy Thanksgiving
PSC makes a quality box.
What issues are you having?
@toximus The steering is sloppy, a lot of play and a little scary on the highway (I wouldn't want my wife to drive it), I'm not comfortable either. In the last month I have converted all of the steering linkage from TJ to ZJ-tie rods, ball joints ect . Put on Zone 3 inch lift with 33 inch tires and aligned. I have screwed the hex bolt flush to the nut on the gear box-no change noted. I ran the model number on the gear box-it happens to be a Cardone.
The PSC one must be good for $900, but it's probably out of my wheel-house. I'm always up for suggestions. Thank you.
Have you tried doing a dry steering test?
I have a 06 TJ with a stock box and I realized in order to tighten up my steering box I had to BACK OFF on the screw, not screw it in further which made it worse.
You are not kidding....I watched some you tube videos and they all say to screw it in....I did that and had about 10" of play. The Mercedes gear box on my 2005 HAS TO BE SCREWED OUT to be tightened up.....what a pain!! I need a new box as well......
Large tires and rock crawling are hard on the stock box. If you do extreme stuff it’s not going to last and PSC may be your best option. if you don’t Check out Redhead Steering gears web site. Then call them. They rebuilt mine about 3 yrs ago. If you’re not the hard core crawler on big tires they are a good option IMHO.
Any updates??
Any updates??
