2004 TJ 42RLE Automatic Transmission Crank Position Sensor
janpoe
Goodyear, AZ
I am trying to find the Crank position sensor on my 2004 TJ 4.0 with an automatic trans. I have looked where everyone says it should be but nothing there.
It does have cam position sensor and was wondering if this year did not have Crank position sensor and just uses the Cam position sensor,
Above starter on passenger side of bellhousing.
Really?
It's on the drivers side of every jeep I've ever been under (which does not include an 04). Have access to a 97 & 00 automatics, and they both have them at about the 11 o'clock position on the bell housing (when viewed from the back looking forward).
Really?
I just replaced the crank sensor on my 04 auto lj. It is thereon passenger side.
Check here...
Reactions: TJTJ04 and L J
Well I'll be...
If you don't learn something new every day you're actually getting dumber relative to the field.
