$150 shipped, you want the airbag correct?How much for the steering wheel shipped to 07876
Sorry that part is already gone.I’m needing the connector that goes to the speed sensor. Not the speed sensor or the female plug, but the male end and as much wire of the body harness side as you’re willing to send?
Sorry I don’t have the hose/pipe to the intake, it went with the motor. Do you still want it?Ok how much for the air box complete with hose and pipe to intake/throttle body.
shipped to 92656?
$100 assuming I can fit it in a flat rate shipping boxPrice on the steering box shipped to 46060.
Thanks
No thanks, looking for the whole enchilada.Sorry I don’t have the hose/pipe to the intake, it went with the motor. Do you still want it?
You need the pigtail with 3 pins that is connected to the speed sensor, correct?
Correct!You need the pigtail with 3 pins that is connected to the speed sensor, correct?
Ok, thanks I wasn’t sure. I still have it, but it’s attached to the tcase which has been spoken for. If that falls through I’ll let you know.Correct!
Sorry, I sold that with the motor.I’m needing the part on the left of the picture. Not the actual speed sensor pig tail. So the part I’m needing would end up tying into the body harness.
